Home › Forums › Product Discussion & Questions › BeoGram › 3400 speed adjustment
- This topic has 4 replies, 3 voices, and was last updated 3 years, 5 months ago by
Tonymaine.
14 October 2022 at 09:33 #39805
Tonymaine
BRONZE MemberNewby to beograms but experienced lightly in other decks. Got a 3400 5726. Replaced belt still running at 32.9 RPM. Where is the fine adjustment located?
15 October 2022 at 05:50 #39806 Mark-sfBRONZE MemberThere are small knurled knobs under the black trim aligned with the speed indicators.
15 October 2022 at 07:23 #39807Dillen
ModeratorA red fingerwheel sticks out at the rear of the operating panel – towards the platter, for fine adjustments.
A lit digit is on the panel right above it, indicating its setting. See the user manual.Base adjustments can be accessed through holes the Beograms bottom plate.
15 October 2022 at 14:07 #39808Tonymaine
BRONZE MemberDuh. Thanks. All good now.
15 October 2022 at 14:11 #39809Tonymaine
BRONZE MemberSorry. Forgot. I can only find service manual online. Is there a use manual
