Home Forums Product Discussion & Questions BeoLink Masterlink – Play button turns whole system off Reply To: Masterlink – Play button turns whole system off
#76465
Madskp
GOLD Member
After a lot of messing about with routers and IP addresses etc, I eventually got the thing connected to a web browser and was able to check it was set as V. Master. Then connected it to my Masterlink setup, turned everything on in hopefully the right order and… no change. Play button on a ML-connected link device still turns everything off. I have not done extensive testing with lots of different IR eyes and devices but have tried various sorts of turning things on and off again.
Not sure if it has an effecgt, but have you tried to power up the NL/ML Converter before the other parts in the system?
I do not have acces to my NL/ML converter at the moment, so it will be some time before I can share how my settings for it are
