Home › Forums › Product Discussion & Questions › BeoLink › Masterlink – Play button turns whole system off › Reply To: Masterlink – Play button turns whole system off
carolpa wrote:
the BLC (NL/ML converter s not “crippled”!the first BLC sold had these ports covered with a plastic strip. It, the strips, can easily be removed.
then the PL, Line in and IR connections are available and working. See a picture of a later version to determine which port is which.
Amazing! You’re quite right. Thanks @carolpa! I’ve peeled off the white plastic strips and there they are – two more RJ45 ports and two Kinch/phono sockets. That’s a world of future fun if I can ever get it configured properly!
just ask what you want to achieve, there is almost always somebody over here with the right advice, also for the somewhat complex settings of a Beolink NL/ML converter.
