Home › Forums › Product Discussion & Questions › BeoLink › Masterlink – Play button turns whole system off › Reply To: Masterlink – Play button turns whole system off
If you are going to use an IR eye for it be aware that you will need the newer type with a join button to be able to use the buttons on the IR eye. If you however only need the IR functionality you can wire up the one of the older ML or MCL IR eyes but only connection to ground, +5V and data.
That’s really useful to know, thanks. By chance I have an IR eye for a Beosystem 3 which has more connections inside than the standard round eye. Do you know if that would work with the NL/ML Converter? It’s just sitting in my spares box otherwise.
Favourite Product: Beolab 3000
