Home Forums Product Discussion & Questions BeoLink Masterlink – Play button turns whole system off Reply To: Masterlink – Play button turns whole system off
#74913
Madskp
GOLD Member
Well I missed out on the Beosystem 3 but have successfully outbid everyone else in the entire world on a NL/ML Converter which will hopefully arrive for the weekend. The madness continues!
Hope this will suite you well. The NL/ML converter is a very versatile device and usefull for many type of setups.
If you are going to use an IR eye for it be aware that you will need the newer type with a join button to be able to use the buttons on the IR eye. If you however only need the IR functionality you can wire up the one of the older ML or MCL IR eyes but only connection to ground, +5V and data.
