Home Forums Product Discussion & Questions BeoLink Masterlink – Play button turns whole system off Reply To: Masterlink – Play button turns whole system off
#74275
carolpa
So I just did some testing with some of my equipment:
Beocenter 9300 – 7 pin datalink cable –  1611 – masterlink cable – Beolab 3500 MK1 both with, and without a powerlink cable between the BC9300 and the 1611.
Beosound Ouverture – Masterlink cable – Beolab 3500 MK1
In bot cases I get the same behaviour as you describe even when I start the music from the master system.
Now what I expected. I will see if I have time to look more into this today
speedsixdave wrote:
Do you have the short circuit in your setups, @madskp? No idea if this is actually relevant or not.
I am not sure. Most of my stuff is in a non permanent setup, so I often switch cables between different units. I will try to check up on this when I have some time, probably in a couple of days.
carolpa wrote:
Normal in ML : short STBY will stop only the product in the room addressed. Long STBY will put the whole system in standby.
That is also what the manuals for the link products describe, so even more puzzling that I can reproduce this issue with two different Audio Masters.
Will also try to look into trying with other components if the above does not change anything.
The T1611 was designed to connect a non ML Audio to a ML Video – or – to connect a ML Audio to a non ML Video.
In the proposed settting the Video ML/ Video non ML is missing. Maybe this is the cause of the behaviour.
Note: I have a Beosystem 7000 – T1611 – BLC connected in my Netlink. I have to set the BLC up as VMaster to work correctly if I’m right (note: I have to check this though! Currently the Beosystem 7000/BLC is out of order, starting early next week it is up and running again).
