Home Forums Product Discussion & Questions BeoLink Masterlink – Play button turns whole system off Reply To: Masterlink – Play button turns whole system off
#74272
Madskp
GOLD Member
Do you have the short circuit in your setups, @madskp? No idea if this is actually relevant or not.
I am not sure. Most of my stuff is in a non permanent setup, so I often switch cables between different units. I will try to check up on this when I have some time, probably in a couple of days.
Normal in ML : short STBY will stop only the product in the room addressed. Long STBY will put the whole system in standby.
That is also what the manuals for the link products describe, so even more puzzling that I can reproduce this issue with two different Audio Masters.
Will also try to look into trying with other components if the above does not change anything.
