Home Forums Product Discussion & Questions BeoLink Masterlink – Play button turns whole system off Reply To: Masterlink – Play button turns whole system off
#74269
carolpa
Just a general note in this discussion:
  1. only BL Passive is active with a source of the BM6500. STBY will switch out all
  2. BM6500 is local active as is the same source on the BL Passive. STBY in the room with the BM6500 should mute the BM6500.
  3. BM6500 is local active as is the same source on the BL Passive. STBY in the link room with the BL Passive should put the BL Passive in STBY.
So be very sure that de IR of the BL Passive and the BM6500 do not receive the signal at the same time.
Normal in ML : short STBY will stop only the product in the room addressed. Long STBY will put the whole system in standby.
