Home › Forums › Product Discussion & Questions › BeoVision › BeoMedia 1 (Beovision 9) › Reply To: BeoMedia 1 (Beovision 9)
Thanks again. I now have a repaired and working Beomedia. I took a ghost image of the installation and also a copy to another hard disk for back-up, upgraded the RAM to 1GB and put a larger 500gb SATA hard drive inside the unit, using an IDE to SATA converter. If you get Microsoft DART V5 you can create a bootable USB and use Ghost 11.5 to make a copy of the installation. What a week it has been but nice to have it working. If yours is the same main board as mine, look at this manual for power supply options: https://theretroweb.com/motherboard/manual/um-epia-mii-162-63cd39724e43c965057015.pdf
Ironically there is no reason the whole system could not be ported to a different PC.
