August 2, 2022 at 4:27 pm
#7294
Hi and welcome to Beoworld!
Maybe try resetting the base using the connected Beocom 6000. Perhaps it has too many phones registered to it.
Assuming the Beocom 6000 is a Mk2 (with an INT button) enter the sequence 9#9#9* and press INT. Use the scroll wheel and choose reset base.
EDIT: I think you can also reset the Beocom 5 using the same 9#9#9*INT sequence.
This reply was modified 2 weeks, 1 day ago by
Guy.
