Home › Forums › Product Discussion & Questions › BeoVision › BeoMedia 1 (Beovision 9) › Reply To: BeoMedia 1 (Beovision 9)
26 January 2026 at 17:24
#72872
SILVER Member
You’re right, the B&O engineers did not think to make it easy on us, but your pictures are exactly what I need, so thank you. To get the power supply off you need a very long but narrow flat headed screwdriver to gently push the clip that hold in outwards. You can then gently rock and pull the powersupply off.
