Home › Forums › Product Discussion & Questions › BeoGram › Beogram 3000 Type 5214 signal wiring › Reply To: Beogram 3000 Type 5214 signal wiring
17 January 2026 at 20:54
#72662
I’m not sure I understand your question. The solder connections all look sound. By rewiring are you planning to replace the wire? These are simply terminals so as long as they match the other side’s wiring the order doesn’t matter.
