Home › Forums › Product Discussion & Questions › BeoLink › Beolink 5000 repair › Reply To: Beolink 5000 repair
My plan is to get one working remote out of the two
If both display are likely working it is more than the majority of BL5000 still in use (got one myself without display) and both will deserve proper repair.
I can’t help regarding capacitors but you might find help searching BWI or BWII.
About the display: you may wait for a confirmation from any other member but when I was still believing my faulty display was from bad soldier join, I bought a T soldier tip fitted with some sort of rubber, made to secure the kind of bond that link the remote to the display. It was pretty cheap so maybe trying it would help someway. In my case it was the ribbon cable that was broken so the tool was of no use.
Good luck.
