Home Forums Product Discussion & Questions BeoVision Masterlink issues: Beovision MX8000 – Beosound Ouverture for DVD audio Reply To: Masterlink issues: Beovision MX8000 – Beosound Ouverture for DVD audio
#71541
neil.mcdowell
Ok, played around a little, but not made much progress unfortunately…
on some points raised, yes the MX8000 is equipped with the Master Link module.
It is however not connected directly to the Ouverture, instead there is a 4-way ML Junction box sitting between the TV, Ouverture and a Beolab 2000 (link room).
Idid install the junction box myself, but checked continuity across all links in the junction box, can access TV audio from the BL2000 module, and play CDs/Radio on the Tv as Yann described.
Following the instructions for DVD audio on the Ouverture, AV + DVD puts it into V.AUX mode, and the speakers switch on. Volume is adjustable without interfering with the TV, but alas, no audio.
If I put the DVD player/TV into standby mode, the Ouverture doesn’t follow suit, and instead is active until shut down.
Not sure if that helps with anything…
Appreciated, Neil
