Home Forums Product Discussion & Questions BeoVision Masterlink issues: Beovision MX8000 – Beosound Ouverture for DVD audio Reply To: Masterlink issues: Beovision MX8000 – Beosound Ouverture for DVD audio
#71445
YannChris
GOLD Member
Then,
To get DVD:
  • On the 8000: DVD
  • On the Ouverture AV+DVD
To get Radio:
  • On the Ouverture: Radio
  • On the 8000: AV+Radio
If your preferred listening position is the same for audio and video, the best solution would be to hook the speakers to the TV.
If my memories are good, you could take benefit of the “central balance” function to enlarge the video stage
And this case, the AV key on source while selecting a source is no more necessary.
Hope this helps.
Regards,
Yann.
PS: is the MX directly connected the Ouverture or is there a black box (converter) between the 2 products?
