Home › Forums › Product Discussion & Questions › BeoSound › Beosound 9000 with 3x BeoLink Passive zone issues? › Reply To: Beosound 9000 with 3x BeoLink Passive zone issues?
When I initially set up I had the beolabs playing by using the remote and then pressed play on the ir eye. After I disconnected the beloabs I used the remote to control the ir eye.
Only two things occurred between it working and not. I used the remote to turn on a non-b&o tv, and an electrician changed a dimmer switch.
The IR eye had a loose connection so I replaced the lead for a new one. I find it odd how the IR eye is receiving a signal from the remote (it blinks when I hold the OFF button or blinks when I follow the process you showed above) but cannot process a proper command. I am tempted to purchase another masterlink cable to see if it is the problem?
