paddy2042
GOLD Member
Sorry a bit of confusion. There is no BV8 in the equation as this is toehold TV that has been replaced by a Samsung!
It is BC2 BS3 and BS9000 that are plugged together with the 9000 cabled in another room. It is this 9000 for playing CD’s that will not take any commands from the main room. It used to work with the BV8-40 but will not with the BS3.
I tried your trick of removing the Masterlink for the BS3 but it made no difference.
DVD in BC2 is connected to BS3 via SCART and does work with the Masterlink removed as you suggested, but it worked before. This is a real conundrum and very annoying.
Thank you for your suggestion as I am willing to try anything to get it working again.
Paddy2042
