Home › Forums › Product Discussion & Questions › BeoMaster › Beomaster 3000-2 Type 2402 15V Power Supply Not Activating › Reply To: Beomaster 3000-2 Type 2402 15V Power Supply Not Activating
7 November 2025 at 13:11
#70966
SILVER Member
Also bear in mind that some components can measure up fine when tested, but fail under load…..I’ve had this issue in the past, and replacement parts from suspect suppliers should be avoided…early transistors can still be found as old stock and are a safer bet than ebay
Craig
