Home › Forums › Product Discussion & Questions › BeoLink › Using Beosound 9000 and Beosound 4 in the same system › Reply To: Using Beosound 9000 and Beosound 4 in the same system
28 October 2025 at 19:40
#70750
GOLD Member
I have been thinking again about your setup @carolpa, and sorry for all of these questions, but if I get more than one Beolink Converter NL/ML, how exactly does that work?
- How do you control the devices in each room – via the device, or via the BLC (with an IR eye perhaps)?
- Does this work with your speakers connected to the ML device, or do the speakers need to be connected to the BLC directly?
- How are your BLCs set up – are they set as source centres? Do you need to use IR mapping options?
- Can you play the source from one room in another room? If so, are there any limitations to that?
- If I have my Beosystem 3 as a video source in Opt.2 and my Beosound 9000 as an audio source in Opt.0 (in the same room), could they both be connected to the same BLC?
I do have one BLC NL/ML which I bought to connect my Beosound Moment into my network, but it never really worked the way I wanted it to, and anyway I prefer my Beosound 5 over the Beosound Moment, so neither the Moment or the BLC are in use right now.
