Home Forums General Discussion & Questions General Discussion & Questions Impossible to disable the DVI locked for the DVB on my Beovison 7/40 MK1 Reply To: Impossible to disable the DVI locked for the DVB on my Beovison 7/40 MK1
#70165
Millemis
Hi Guy
I must contradict you, I fear.
It is however, a long time ago, but if I recall well:
At some point with the BV7 MK1 B&O used the so-called ‘DVI-solution’ for the HD-tuner…..because it offered a better PQ.
This was indeed ‘internal connected’.
I know of no solution to revert this, apart from opening the tv etc.
@Alcy.
There are plenty of BV7 later MK-versions to get at a very low price…..so why worry with this dinosaur.
Except – of course – you like tingling and solving problems 😉😀
P.S.
There are more knowledgeable people on this subject than me – the only problem will be, if they are present on the forum nowadays.
