Home › Forums › Product Discussion & Questions › BeoCom › Beocom 5 won’t connect to base › Reply To: Beocom 5 won’t connect to base
So if you use the BC6000 to go to the ‘select base’ menu (DOT MENU 7 then ‘select base’) is there only one base listed when you use the wheel to scroll? I only ask this because I can not convinced that a handset reset deletes all the data. (From memory, I think at least handset name stays).
Yes, only one base is now shown in that menu.
I can’t find a BC2 Mk1 manual (I only have Mk2) to see if it also has the ‘select base’ menu anyway.
I think on the Beocom 2, it only allows you to have one base registered. I regsitered mine to a new base when it was already registered to one, and it seems to have just switched one base for another.
