Home › Forums › Product Discussion & Questions › BeoCom › Beocom 5 won’t connect to base › Reply To: Beocom 5 won’t connect to base
Useful, thanks.
There is a Beocom 6000 Mk1 already linked to the Beoline Mk2, so that should meet that criteria.
Above the table it does also specify that the software must be updated. I have no idea what software either the BC5 or the BL Mk2 has.
Asa I mentioned about, if I try DOT 70008 OK to get into the service menu for the BL Mk2, I only get ‘Not Base 1’ displayed, which I don’t understand and the BC6000 is linked only to that one base.
I reset the BC5 when I got it, so now the only thing it displays is ‘Register to base?’. The handset software is 2.43, but I don’t know if that means it should be linkable to a BL Mk2!
