Home › Forums › General Discussion & Questions › General Discussion & Questions › Finding the correct BLI B&O macro command › Reply To: Finding the correct BLI B&O macro command
29 September 2025 at 18:27
#69993
I have my Kaleidescape player using the “TV” source on the Beovision 10. The NL/ML Converter is in the same room with it’s IR eye near the BV10 so it’s getting the same IR commands. I don’t have speakers connected to the NL/ML Converter.
The BLI macro is using the trigger of CONTROL + PRESS + CONTROL.
