Home Forums General Discussion & Questions General Discussion & Questions BeoBabble – a B&O multi-protocol interpreter Reply To: BeoBabble – a B&O multi-protocol interpreter
#69963
TK
Thx pl212 for your offer, I’ll gladly accept.  I’ve been slow to release the software for GA because I wanted to make sure that I got the syntax mostly usable, and I’m also suffering a bit from feature creep.  More on that in a following post.
This following solution is not really a good final solution, but I’ll mention it anyways as a thought exercise: at a minimum what would work with little effort is if you had 2 sources that you connected via a Y-cable to BeoBabble, and connected the BB DL86 output to an ML/MCL converter, which then connected to the BC2300. On a start signal from either source, the BB can be easily modified using a macro to send a DL86 “System-on, switch to Aux” to the BC23000 through the ML/MCL when BB detects a “Playing” Status from one or the other source, and also send a “Pause” signal to the other source, much in the same way a BeoMaster does when you switch sources.  So that part would work already, but I think it would be a bit of a kludge, and likely introduce some unwanted noise interference.  There would also be some wiring needed to bridge the audio pins, which I currently have not spent much time on.
So the BB Setup would look like this:
2 BB Macros: On DL80 Trigger “Beogram.Playing”, Send DL80 “BeoTooth.Pause”; Send DL86 “BC23000.Src=>Aux”;  On DL80 Trigger “BeoTooth.Playing”, Send DL80 “Beogram.Pause”; Send DL86 “BC23000.Src=>Aux” (Which I assume would power the BC2300 on as most B&O conventions allow for)  In theory (THEORY!) that would kinda-sorta work out of the box with just a couple of Y cables, but AFAIK it’s not really the best idea to have two sources sharing a common output channel without having a proper MUX that can isolate each source’s audio signal from the other, and switch cleanly between them.  What we are doing in this example is sharing an audio L+R, and shutting one system off if the other starts playing – probably not recommended.
Getting into the weeds here, so indulge me and feel free to ask questions or offer a clarification if I’m off-base: with respect to the BC2300, I think that it speaks ML, and not MCL2, which would mean for the moment that there would be a bit more hardware to acquire in the form of an ML/MCL converter just to get the communications working (I’ll get to ML support at some point in the future, but probably it will be a while), and then also an additional piece of hardware in the form of an Audio MUX that has, say, 2-4 input channels and an output channel for the BC2300 Aux connection, and the channel selection would have to be settable via a logic signal that BeoBabble can send out.
So, what am I saying? I think it <could> work out of the box, but I don’t know that the result would be great without a proper audio MUX. It’s clearly worth exploring what it would take to put a MUX like you would need on-board, but my experience is not in audio engineering, so my hope would be that someone resourceful could help design one, or offer another hardware audio MUX solution to with an API/Interface.
Keep those product extension ideas coming!
