Home › Forums › Product Discussion & Questions › BeoLink › Beolink Converter IR mapping? › Reply To: Beolink Converter IR mapping?
But how are the A.aux command mapped in this situation? Or is that not going through the NL/ML converter?
Both N.Radio and A.Aux are mapped to A.Aux in the NL/ML Converter, which seems to work.
But what about N.radio? Is the BS5 not responding when you use that for the redcord player scenario?
It tries to, but my BM5 has no internet connection, so N.Radio appears on screen, but paused.
I have however experienced another issue. Because both my BS3 and the NL/ML Converter have IR eyes connected, both are responding to remote commands, so for example if I hit 1, I get 11. I tried setting the BS3 to Opt.0, but if it’s in Opt.0, it does not come out of standby at all when I select a source. If I set it to Opt.1, it only responds to video sources, not audio sources (My Beosound 4 is set to Opt.0, and I’m sure that’s the only right option to use there, as my speakers are connected to the BS3). This feels like something there should be a solution to, but I haven’t found it yet!
