Home › Forums › Product Discussion & Questions › BeoLink › Integration of BeoSound 3000 without speakers in to BeoVision 11 › Reply To: Integration of BeoSound 3000 without speakers in to BeoVision 11
5 September 2025 at 10:12
#69382
Thank you for your continued support.
I have drawn up (what I understand) is the correct configuration for a cable from Power Link to AV and a cable from BS 3000 AUX to AV. Please check for me if they are correct (see files attached).
One question remains: Which pin should I solder the breaded wire to at the AUX end? Or should I not need to bother with that?
