Home Forums Product Discussion & Questions BeoMaster Access OPTIONS on Beomaster 7000 Reply To: Access OPTIONS on Beomaster 7000
#69166
Madskp
GOLD Member
– Disclamer start: I do not have much faith in auto generated answers from chatbots – disclamer end –
Very hard to decipher the Chat GTP conversation, but before you start paying money to repair your Beomaster 7000 you should consider a few things.
If your setup is actually connected like the sketch in this posthttps://forum.beoworld.org/forums/topic/access-options-on-beomaster-7000/#post-68804 and the Pentas are connected to the TV and only the TV the the Beomaster 7000 has nothing to do with volume control in your main room. The volume for the Pentas are regulated by the device they are connected to, hopefully the TV as advised bye me and other members earlier.
DO NOT CONNECT THE PENTA SPEAKERS TO THE BEOMASTER 7000 IF YOU WANT THIS SETUP TO WORK
Also as far as I iunderstood the devices you had volume troubles with and Apple TV and the PC source, both something connected to the TV. As advised before I would look into the speaker group setup for these connections. Based on what you are telling it sounds like the center speaker on the BV7 might not be in play for dialogue.
