Home Forums Product Discussion & Questions BeoCenter Beocenter 1 with Suspicious Display and IR Board (PCB58) Reply To: Beocenter 1 with Suspicious Display and IR Board (PCB58)
#69164
Narles
Thank you so much for responding and telling me about this. I had thought about removing the metal shield but I will go ahead and do that (after I try checking that it hasn’t somehow switched to option 0). If it is the capacitors under the shield, I am guessing those would be surface mounted components since the back of the PCB has no through-holes in that section?
Thanks again. This is my only B&O product so it really helps to hear from someone with more experience. I tried getting help from the CRT TV enthusiast community but it seems that B&O TVs are such a different kind of product that the regular CRT TV enthusiast community can’t really offer much help for issues like this. Thanks again!
