Home Forums Product Discussion & Questions BeoGram Problem with Beogram 4002 Type 5521 Reply To: Problem with Beogram 4002 Type 5521
#69090
Mark-sf
When you press start, the inward movement of the tonearm activates a switch on the slide PC board that causes it to remain on. If that is not happening you will get that problem. If you keep holding the Start button, does the arm advance to the middle as long as you hold it as it should?
