Home Forums General Discussion & Questions General Discussion & Questions Beolab 3 – Questions regarding setup Reply To: Beolab 3 – Questions regarding setup
#68317
Millemis
A Powerlink connection (one cable) carries two channels.
This means that you can use the mentioned adapter for two speakers i.e. your left and right BL3.
That must be configured in the sound menu of the BV for the PL socket you use.
However, the BL2 needs its own socket to be configured correctly.
Meaning that you will also need an adapter for that (a single RJ45 to Din female).
After connecting that to a PL socket on the BV that can be configured appropriately.
You then end up with a 3.1 setup (the internal speakers must be configured a the center speaker).
In case you later on should want to expand, you just need another splitter (like the one mentioned) and – of course – the BL’s configured as surround L/R.
All set up you can create Speaker Group – for Movie typically the 3.1 configuration and for Music (radio etc) typically a 2.1 configuration.
If you want to dig deeper and learn about the multiple options of the BV11, please read here:
https://bangolufsenassistentgohe.blob.core.windows.net/manuals/TELEVISIONS/technical_sound_guide_televisions_2201.pdf
