Home Forums General Discussion & Questions General Discussion & Questions Beolab 3 – Questions regarding setup Reply To: Beolab 3 – Questions regarding setup
#68285
Millemis
Congrats!
When connected to a BV, you should definitely connect the BL3’s and the 2 seperately.
Otherweise you will not be able to configure the setup correctly.
Connecting the 3’s via the 2 is correct, when you connect to a Beomaster/Beosystem/Beosound (i.e. not the BS Theatre) such as a BS3000.
There you have no option for setting the distances etc etc.
Please consult the userguide of the BV to find explanations of how you connect external speakers.
This said – it is possible to do what you have done – but it is certainly not the best way, and nothing that I would recomment.
So, yes – you will need adapters
Best set each speaker up seperately.
