Home › Forums › General Discussion & Questions › Beocentre 9500 Outputs › Reply To: Beocentre 9500 Outputs
16 July 2022 at 09:13
#28294
Great point trackbeo – I would definitely try a cable change first as a possible (probable?) solution. Also don’t use your stand alone pre-amp – it’s not needed.
Here’s the type of cable to which trackbeo referred: https://www.ebay.co.uk/itm/284178585525
(That’s not a specific supplier recommendation – I just did a quick search on eBay!)
