Home Forums Product Discussion & Questions BeoMaster Beomaster 4500 IR Noise/Buzzing Reply To: Beomaster 4500 IR Noise/Buzzing
#67924
Madskp
GOLD Member
I belive the hardware for the two way is there even though the software is not ready for it ( bonus info: instead the 1.6 SW will let the BM4500 work as a link room).
That said the two way functionality might still do something even though the software is not complete, which is prooved by your IR transmitter flashing (unless its because you actually have a newer software in it). And that might activate some signaling on the datalink part.
Regarding disabeling of the two way. As far as I know the BL7000 decides if it is one way or two way when you register components in the setup menu on it. How that works if the product is partly capabale of two way I dont know.
