Home › Forums › Product Discussion & Questions › BeoLink › MCL2AV Tone Control › Reply To: MCL2AV Tone Control
26 June 2025 at 20:13
#66689
SILVER Member
Hello,
Thanks for the reply.
I also checked the circuitry, and came to the same conclusion.
Playing the main room sources, “sound” will certainly adjust the Beomaster.
However, sound x times seems to do something in “local mode”. (When main room BM is asleep) It appears to be one or two settings in addition to volume control.
At the moment I am using a local non-beo source (radio+shift+7) . This doesn’t allow two-way communication via Bl5000.
Maybe I should try to connect a data link compatible beogram or beocord.
