Home › Forums › Product Discussion & Questions › BeoSound › My journey through a B&O youngtimer (Beosound 1 Cone). › Reply To: My journey through a B&O youngtimer (Beosound 1 Cone).
Hi Madskp,
1- I believe the antennas are the two side strips on the lower body of the unit. In the top part all I’ve seen looks like controls parts (rotating volume and touch panel. Nevertheless, Wifi does’nt seems to be the issue. More likely the link between the app and the device.
2- Yes I’ve tried to reset the unit (thus erasing the wifi credentials) and use ethernet only: same behavior, the app sees the unit because it sets the gold color in the app and after that cant establish connection. Then again, even in wireless mode, the airplay connection is steady and strong.
3- No, but see above.
4- Yes it has and it was quite a surprise. The web server is the same as the one in the playmaker or the Beolit 12, same look and features that the Beosetup App.
Then, yes, it could be a good place to try the update. But I’m still reluctant to do it (Years of Apple Update Anxiety…).
Thank you for your help.
