Home Forums Product Discussion & Questions BeoMaster Beomaster 6000 4channel Lamp Replacement Reply To: Beomaster 6000 4channel Lamp Replacement
#66285
hcraig244
SILVER Member
Hi
Are you changing out all the lamps on the machine or just those that have failed? Some lamps are fitted into an enclosed plastic compartment, others are not. You will need to open the unit up to access all lamps…..check out the service manual available here for a better idea, be sure to replace the lamps according to the description provided by the supplier, the current ratings differ from location to location…….enjoy 👍
