Home › Forums › General Discussion & Questions › General Discussion & Questions › BeoLab 3500 MKI to BeoLink NL/ML › Reply To: BeoLab 3500 MKI to BeoLink NL/ML
4 June 2025 at 05:16
#66190
GOLD Member
Since you have no audio or video master on your masterlink side, you need a master link power box. B&O part # 8052447.
You can read more about it on pg 29 of the BeoLink Handbook http://beointegration.com/uploaded/EN-BeoLink-handbook-v1-7.pdf
Alternativly you can use a Beolink converter type 1611. That will also supply the needed power and might even be cheaper and more available. Also this can give an extra local input if needed.
