Home › Forums › Product Discussion & Questions › BeoGram › Beogram CD-50 – Lower Disc Holder 9132 › Reply To: Beogram CD-50 – Lower Disc Holder 9132
So a note of warning – the sound heard in the video posted above in my case was not related to the spindle motor issue which the comments suggested was the issue.
Ok good to know. Will experiment a lttle more with the brass know before going into motor issues.
For the temperamental issues of the player have you tried cleaning the laser lens – and are the cams on the laser housing all complete and lubricated?
Laser cleaned and all gears in the laser housing is lubricated. Have not checked for small cracks or missing teeths on the gears, so will also do that.
On your player #1 have you noticed if the CD start the counter at 0.00 or if it is a minute or more into the first track?
