Home › Forums › Product Discussion & Questions › BeoMaster › Beomaster 2400 Restoration Problem › Reply To: Beomaster 2400 Restoration Problem
6 May 2025 at 16:01
#65459
Member
Hello Madskp,
Sorry for the slow reply, I have had trouble connecting to Beoworld. I do appreciate the reply. There are a couple of copper wires that connect the main board to the “chassis” of the BM 2400 which I unsoldered while replacing the parts, and soldered them back after I finished. I will check the other cables that run to that board. From the two comments I have received so far, the fault does not seem to be connected to me trying to get the front panel touch pad connected correctly.
