Home › Forums › General Discussion & Questions › General Discussion & Questions › Will Mozart support Masterlink sources? › Reply To: Will Mozart support Masterlink sources?
21 April 2025 at 10:01
#65208
It seems that they are not interested – quite a lot of users have asked that question.
Only way is to start the source (e.g. the CD) manually or with the Beo4/the BROne in ir-mode and then ‘Join in’ from the Mozart product.
I do this with my 6500 Master/CD (and the Converter) on my Theatre…..it works.
You get used to it……but it is unfortunately not ‘the real thing’.
