Home › Forums › Product Discussion & Questions › BeoLink › A.Aux Link, Masterlink and Network Link – 3 B&O generations together? › Reply To: A.Aux Link, Masterlink and Network Link – 3 B&O generations together?
Somehow, and I have no idea how, the Moment has stopped responding to IR commands. I have no idea why, I must have changed a setting without realising it, but that works for me so I’m not complaining!
As for the buzzing noise in my Penta’s when the display changes – I’m now 90% sure it’s the 1611 Converter that is causing this. When I used my Beosound 4 instead of Beocenter 9500 (and therefore did not need toe 1611), I never got the buzzing noise. If I select a source on my Beovision 7 and change channel or volume etc, I don’t get the buzzing noise. I only get the buzzing noise when an audio source is selected, so it’s coming through thew BC9500 and the 1611 converter.
I have my 1611 connected by both A.Aux able and Powerlink (Mk3) cable. I unplugged the Powerlink cable to test if that got rid of the buzzing, but it didn’t.
It’ll take some effort because my cables are all routed and hidden, but I’ll try and switch out some of the cables between the 9500, the 1611 and the Pentas, in case one of them has a fault. It’s also possible I suppose that my 1611 has a fault.
