Home › Forums › Product Discussion & Questions › BeoLink › A.Aux Link, Masterlink and Network Link – 3 B&O generations together? › Reply To: A.Aux Link, Masterlink and Network Link – 3 B&O generations together?
Thanks – I have looked at other threads already and done so again today but other than having more than one NL/ML Converter (and I don’t want to go to that amount of trouble), I don’t think there’s a solution.
I’ve tried every setting in the NL/ML converter and I’ve tried every setting in the Moment, but I can’t get full integration from any set of options. Either the Moment works through the speakers, or the Beocenter does, but never both.
Having the Moment to the Tape 2 input of my Beocenter via an adapter cable seems to be the best option for me then. At least it works.
One thing I’ve noticed from this set up though – when I select a source, or change the volume, or press any button really, I get series of between 1 and 3 short quiet buzz noises coming from the speakers. It seems to happen with any button press, whether by remote, or on the Beocenter panel itself. Probably caused by the 1611 converter as I never got that before noise before I connected that, but I wonder if anyone knows the cause?
