Home Forums Product Discussion & Questions BeoCord Beocord 1200 – Problems with playing newly recorded tapes Reply To: Beocord 1200 – Problems with playing newly recorded tapes
#64846
YannChris
FOUNDER Member
Your alcohol should make the job.
On your picture, the left head is the erasing one. The right one is the play/record one.
Clean both with cotton swabs lightly soaked in alcohol
These heads, manufactured by Bogen are known to be fragile and prone to failure.
I had the same problem with a Beocord 2000 and unfortunately couldn’t solve the fault.
Yann.
My B&O Icons: No description available No description availableNo description availableNo description availableNo description availableNo description availableNo description availableNo description availableNo description available No description available No description availableNo description available No description available
