Home › Forums › Product Discussion & Questions › BeoLink › Powerlink Comptability › Reply To: Powerlink Comptability
I got my BC8500 and BG8500 out of storage this weekend, so was able to carry out one more test: Test 5 – BC8500 > MLL2AV > BL Penta – Partial Pass Connected via PL Mk2 cables so they will transmit the display data, but no display on the Pentas. Sound was fine, but no display.
Thanks or taking the time to test it. I thought for sure that configuration would work with the dispays on the Penta’s.
I know that the BC8500 will want to go to Phono while the Essence will want to go to N.Radio in response to the PH remote command, but I should be able to get around that using the IR Mapping capability of the NL/ML converter.
Yes probably you can make some workaround, maybe an unused video source can be used. However I am unsure how it will work with the BV7. Probably ok if that video source is not setup to a connection on the BV7
