Home › Forums › General Discussion & Questions › General Discussion & Questions › Hall Audio – closed › Reply To: Hall Audio – closed
26 February 2025 at 23:22
#64135
I use – for an older Philips 32” tv in a guestroom – an ARC Extractor with an Essence MK2 (line-in) and a set of BL3.
Works, but volume control is a bit fiddly.
The tv volume has to be set high…..if I want it louder, I have to use the Essence Remote (or the app).
I assume, that it would have worked smoother with the Hall Audio Streamer or the OneRemote-box with the BL3’s directly connected.
But I wanted the Essence (and Beolink multiroom) in the mix.
That’ll do for now!
If I could get my hands on a V1-32 at a reasonable price, I’d probably replace the current solution.
