Home › Forums › General Discussion & Questions › General Discussion & Questions › Low-Budget Multiroom Setup for Ceiling Speakers › Reply To: Low-Budget Multiroom Setup for Ceiling Speakers
25 February 2025 at 10:38
#64015
Wow, thanks a lot for the information. Very appreciated. So if I understand correct I can choose from the following components:
Main Component:
- Beosound Essence Mk2 (cheap)
- BeoSound Core (medium)
- Beoconnect Core (expensive)
Amplifier:
- Beolink Passice (cheap)
- BeoAmp 2 (medium)
Speakers:
- Every cheap ceiling speaker will do
Correct?
If this assumption is correct, two more questions:
- Are there any active ceiling speakers you are aware of, so that I can skip the Amplifier? My understanding is, no, as they would also need to speak “Powerlink”
- If I have multiple Speakers (say 2 as stereo pair in the kitchen, maybe 1 in the guest toilette and maybe 2 in the dining room, I would need several “main components”, see above. There is no solution where I can have only one “main component” like a Beoconnect Core and drive 3 areas independently, correct?
