Home › Forums › Product Discussion & Questions › BeoGram › Beogram Turntables – which have preamp › Reply To: Beogram Turntables – which have preamp
Ypou’re rifght – it doenslt work. I donlt yet have the adadter to connect my BG3000, but I didn connect the BG3000 to the 1614 via A.Aux link plug, then to my BS4 via Masterlink, just to test if there was any Datalink compatibility. There was not – if I pressed Phono on the Beo4 the BS4 came on (but in N.Radio, of course), but the turntable did not activate.
As for th alternarive possible MCL2AV solution you give – I did have an MCL2AV only recently but had to return it to the seller as it failed after a short while. Madskp’s diagram does have a note bottom-right though saying this solution would not work if a Beosound was used as the audio master, soi I assume Madskp means that my Beosound 4 is not an alternative to a Beoport in this case.
