Home › Forums › General Discussion & Questions › General Discussion & Questions › Problem with MasterLink sources on Mozart with BLC. › Reply To: Problem with MasterLink sources on Mozart with BLC.
I did have my share of problem too. But everything is working fine again.
I never managed to get ML sources visible on a Mozart device directly (BL8/BL28) though, I was surprised to read that you hade it available on your Balance. But that was no issue for me, because I could access them though other devices.
What changed is the BLC sources can directly be started on the BLC in the app and then the BLC can be joined by other devices (Mozart also).
And yes, sometime the Mozart device doesn’t seem to follow the JOIN command. But what does help is to join manually. Mostly thereafter it works fine again (or first start a source on the Mozart device and then join, thereafter it should work again as normal).
note: I have an escape route – I programmed my Halo/BLI to directly start any ML source on any device (also Mozart).
I did have lengthily discussions with B&o about it.
