Home › Forums › General Discussion & Questions › General Discussion & Questions › Beogram motor bearings issue › Reply To: Beogram motor bearings issue
		23 June 2024 at 15:21
		#56953
 RIB2906
RIB2906BRONZE Member
	Hi Martin,
I have checked the motors and you are quite right, all 4 bearings are non-collared so I have ordered 2 pairs to replace them. May I please ask 2 (last?) questions?
1 you mentioned I should use “oil suitable for use with sinter-bronze. It needs to have the
right additives.” Can you recommend one that I should use? I’m thinking of using WD40 white lithium grease spray, would that be OK?
2 Should I spray the oil into the new reservoir felts? Many thanks, Richard.
