RIB2906
Thank you for that advice Martin. That is information way beyond my knowledge and it seems lubricating the bearings may be of limited benefit. May I ask please if I should order Beoparts (now: Danish Sound Parts) “Motor bearings set for Beogram & Beocenter motor with 3mm spindle and one collared bearing” for both types 1203 and 2000/5244?  It may be that I need to first take apart the two motors to check whether or not they each<!–more–> require one collared bearing.
Thank you,
Richard
